S32R274 1Rf_4antenna_Demo_Example
5,288件の閲覧回数
ankush_s
I am getting an error in 1RF_4antenna Demo example.
"TFTP Init Error: Could not create Text file PHY sanity is ok"
 after that execution stops. Please help me to resolve the issue. I have attached the screenshot of the issue.
Ankush
ラベル(2)
3 返答(返信)
5,091件の閲覧回数
jiri_kral
is your TFTP server setup correctly? Please check the example description.txt file.
Jiri
5,089件の閲覧回数
ankush_s
Thanks for the reply, I already figured it out. But now during debugging the z7 core, I am getting the following error
"Config file 0
Error count 1 Code 1000d"
Can you tell me how to solve it and why it is coming?
Ankush Sangwan
5,089件の閲覧回数
jiri_kral
you have bad path to data folder on TFTP server or data folder is missing at all. In my case I have S32R274/data folder on TFTP srver's root. My path is /S32R274/data:
Jiri
