S32K314 cross compiling
wang_q4
Dear all,
When i compiling with cross-compilation chains,prompted"/bin/sh: arm-none-eabi-gcc: command not found,make: *** [src/main.o] Error 127",How can I solve this problem.
jiri_kral
can you please describe more your build system? Assuming that you are using some Linux OS, correct? Did you installed S32 Design studio or only standalone gcc toolchain for ARM?
Jiri
CanCan
Hello, coming from a different project but I am having the same errors. I only installed standalone compiler for arm. I only use linux terminal.
Thanks in advance
