S32K3 - Supported Programmers/Debuggers
2,925 次查看
biju_nair
What are the list of supported programmers//debuggers for S32K3 part, other than PE-Micro debugger ? I saw some literature where it says that Segger is also supported. But, is there any other low cost programmers/debuggers for S32K3 part, other than these two ?
Regards, Biju
2,919 次查看
davidtosenovjan
Along with recommendations from our website below you could also take a look on third party providers’ website:
https://www.segger.com
http://www.lauterbach.com
http://www.pemicro.com
https://www.pls-mc.com
http://www.isystem.com
https://www.iar.com/
Also I could point out to some other solution of production programming (direct programming of MCU over ZIF socket):
https://www.elnec.com
