S32K146 Single Step not stepping correctly
2,093 次查看
albie5
Can anybody advise as to why Single Step functions step-into and step-over both perform the same step-into function. Am I missing some setting somewhere?
标记 (3)
3 回复数
1,989 次查看
albie5
We're using our own project and its optimized code, is that the problem?
1,989 次查看
jiri_kral
yes, in some cases it may be an issue. For debugging purposes is better solution use non-optimized code.
Jiri
1,989 次查看
jiri_kral
can you provide more details like screenshots? Are you using some example or your own project? Did you enabled optimizations?
Jiri
