S32DS v1.2 installation problem
2,068件の閲覧回数
yankuang1
I encountered the following problems installing the software, I tried offline and online activation, but failed。I'm sure my network is normal.
タグ(2)
2 返答(返信)
1,853件の閲覧回数
martin_kovar
could you please try to apply the fix below for correct offline activation behavior?
https://community.nxp.com/docs/DOC-334344
Please let me know, if it works on your side.
Martin
1,852件の閲覧回数
yankuang1
Hi ,
Thank you very much, based on your suggestion, I have solved this problem.
