S32DS for ARM v2.2 installation issue
duosahnyu
Due to various reasons, I am currently reinstalling S32DS for ARM v2.2. After double-clicking the exe installer, the installation interface does not pop up. Instead, only a folder named I1777285553 is extracted in the Temp folder. Inside I1777285553\Windows, there is an S32DS_arm_v2.2.exe. I tried double-clicking it, but it shows the error: "Failed to load Java VM: error 2". However, there is a java.exe under I1777285553\Windows\resource\jre\bin. I also tried running S32DS_arm_v2.2.exe from the command line and specifying the location of java.exe, but there is no response. What should I do in this situation? Do I need to re-download Java?
alejandro_e
Hello @duosahnyu,
Thanks for reaching out to us. I just downloaded and installed S32DS for ARM v2.2 on a Windows 11 machine without problems, so we can discard issues with the installer. Can you try running the installer with administrator privileges? Also, please check if you see a txt file in C:\NXP\S32DS_ARM_v2.2\_S32 Design Studio for ARM Version 2.2_installation\Logs, if so, please share it in your next reply.
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2356528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32DS%20for%20ARM%20v2.2%20installation%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356528%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EDue%20to%20various%20reasons%2C%20I%20am%20currently%20reinstalling%20S32DS%20for%20ARM%20v2.2.%20After%20double-clicking%20the%20exe%20installer%2C%20the%20installation%20interface%20does%20not%20pop%20up.%20Instead%2C%20only%20a%20folder%20named%20I1777285553%20is%20extracted%20in%20the%20Temp%20folder.%20Inside%20I1777285553%5CWindows%2C%20there%20is%20an%20S32DS_arm_v2.2.exe.%20I%20tried%20double-clicking%20it%2C%20but%20it%20shows%20the%20error%3A%20%22Failed%20to%20load%20Java%20VM%3A%20error%202%22.%20However%2C%20there%20is%20a%20java.exe%20under%20I1777285553%5CWindows%5Cresource%5Cjre%5Cbin.%20I%20also%20tried%20running%20S32DS_arm_v2.2.exe%20from%20the%20command%20line%20and%20specifying%20the%20location%20of%20java.exe%2C%20but%20there%20is%20no%20response.%20What%20should%20I%20do%20in%20this%20situation%3F%20Do%20I%20need%20to%20re-download%20Java%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20for%20ARM%20v2.2%20installation%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261964%22%20target%3D%22_blank%22%3E%40duosahnyu%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20reaching%20out%20to%20us.%20I%20just%20downloaded%20and%20installed%20S32DS%20for%20ARM%20v2.2%20on%20a%20Windows%2011%20machine%20without%20problems%2C%20so%20we%20can%20discard%20issues%20with%20the%20installer.%20Can%20you%20try%20running%20the%20installer%20with%20administrator%20privileges%3F%20Also%2C%20please%20check%20if%20you%20see%20a%20txt%20file%20in%26nbsp%3B%3CEM%3EC%3A%5CNXP%5CS32DS_ARM_v2.2%5C_S32%20Design%20Studio%20for%20ARM%20Version%202.2_installation%5CLogs%3C%2FEM%3E%2C%20if%20so%2C%20please%20share%20it%20in%20your%20next%20reply.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E
