S32DS for ARM 2018R1 license
25,144 次查看
binli
Hi:
My license of S32DS for ARM 2018R1 IDE has expired. Could you help check and extend it for me?
Thanks.
25,125 次查看
mikedoidge
I've extended your entitlement. Please refresh or re-activate your installation.
Mike
81 回复数
7,095 次查看
cjgyf
My license has also expired (9DE8-C6AE-8B6B-952B), could you extend it for me? Thank you very much!
7,053 次查看
Mehul_Patel_NXP
Hi, @cjgyf ,
I've extended your entitlement through end of December 2025. Please refresh or re-activate your installation.
- Mehul Patel
8,796 次查看
francesco_solit
Good morning.
Our licence for S32DS for ARM 2018R1 is going to expire. Could you please extend it? You can find it in attachment.
Thank you and kind regards,
Francesco Solito
8,653 次查看
mikedoidge
Hello @francesco_solit,
I have extended your entitlement. Please refresh the license so it will receive the new expiration date.
Mike
8,583 次查看
francesco_solit
Thnk you very much mike.
Kind regards,
Francesco Solito
7,985 次查看
francesco_solit
Hello Mike
The re-activation is now working on my PC, but it is no more working on the other PCs of my colleagues, where in the past the same licence was working. Is it possible to extend the license also for my colleagues? Or is it possible to receive new licences for them? Their NXP accounts are:
federico.bocconi@metasystemcorporation.com
matteo.cocconcelli@metasystem.it
Thank you in advance and kind regards,
Francesco Solito
7,606 次查看
mikedoidge
I checked the server logs for this entitlement. It is reporting the maximum number of returned licenses has been reached. I reset the count, so it should work now. Please ask your colleagues to try again.
Please also note, your colleagues could get their own license if they use the following link and login to their NXP.com account:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-ARM_v2018
Mike
7,218 次查看
francesco_solit
Hello Mike
Sorry for the delay. Thank you very much. Now everything is working correctly.
Kind regards,
Francesco
7,592 次查看
NiceHyuny
Hi, my licence is expired, can you help me to extend it?
The number is
4F70-F0A3-101C-3C96
Thank u so much.
7,459 次查看
mikedoidge
I have extended this entitlement through 2025. Please use the activation code to receive the new license.
Mike
5,192 次查看
Jaydenyzhu
Dear,
my license of S32 Design Studio for ARM Version 2018.R1 has expired. Could you please extend it for me?
Activation Code D5D0-D801-AB24-58DF
Thanks a lot.
5,107 次查看
Mehul_Patel_NXP
Hello, @Jaydenyzhu
I have extended this entitlement through 2026.
- Mehul Patel
5,222 次查看
Jaydenyzhu
Thank you very much. Now everything is working correctly. Thank you again.
7,999 次查看
atranzillo93
The number is
B361-6887-8BBF-ED12
Moreover, also for my collegue Anna D'Alessio:
E735-6A42-FED4-6005
Thank u so much.
Anita
8,188 次查看
mikedoidge
Both entitlements have been extended through 2025. Please use the activation code to re-activate your installations.
Mike
8,655 次查看
valeriaalessi
Good morning,
my license of S32DS for ARM 2018R1 IDE has expired. Could you please extend it for me?
In attachment you can find the current licence expired.
Thanks a lot.
Valeria
8,447 次查看
mikedoidge
Hello @valeriaalessi,
I checked the license server. It reported that you had exceeded the maximum number of returns. I have reset the return count. The issue should now be resolved. Please try once more.
Mike
8,412 次查看
valeriaalessi
Good morning,
I tried to re-activate with the same license number but it continues to tell me that the license is for another feature. However, the second error about exceeded number of returns does not come out again, after the first one.
Could you help me?
Thanks a lot.
Valeria
8,384 次查看
mikedoidge
I have manually returned the license from the server side. When you receive the offer to return the license, please choose 'Yes'. Sometimes there is some setting which does not get reset properly and this will force it to be reset. After this, and with my action to return the license, you should be able to activate without issue.
Mike
8,365 次查看
valeriaalessi
Good morning!
The issue is solved!
Thanks a lot.
Valeria
8,435 次查看
mikedoidge
I have extended your license through 2025. Please refresh from the Help->NXP Licenses menu or reactivate using the same activation code as before.
Mike
