S32DS for ARM 2018R1 license
15,616件の閲覧回数
binli
Hi:
My license of S32DS for ARM 2018R1 IDE has expired. Could you help check and extend it for me?
Thanks.
15,597件の閲覧回数
mikedoidge
I've extended your entitlement. Please refresh or re-activate your installation.
Mike
72 返答(返信)
5,594件の閲覧回数
mikedoidge
Hello @francesco_solit,
I checked the server logs for this entitlement. It is reporting the maximum number of returned licenses has been reached. I reset the count, so it should work now. Please ask your colleagues to try again.
Please also note, your colleagues could get their own license if they use the following link and login to their NXP.com account:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=S32-DS-ARM_v2018
Mike
5,206件の閲覧回数
francesco_solit
Hello Mike
Sorry for the delay. Thank you very much. Now everything is working correctly.
Kind regards,
Francesco
5,580件の閲覧回数
NiceHyuny
Hi, my licence is expired, can you help me to extend it?
The number is
4F70-F0A3-101C-3C96
Thank u so much.
5,447件の閲覧回数
mikedoidge
I have extended this entitlement through 2025. Please use the activation code to receive the new license.
Mike
3,180件の閲覧回数
Jaydenyzhu
Dear,
my license of S32 Design Studio for ARM Version 2018.R1 has expired. Could you please extend it for me?
Activation Code D5D0-D801-AB24-58DF
Thanks a lot.
3,095件の閲覧回数
Mehul_Patel_NXP
Hello, @Jaydenyzhu
I have extended this entitlement through 2026.
- Mehul Patel
3,210件の閲覧回数
Jaydenyzhu
Thank you very much. Now everything is working correctly. Thank you again.
5,987件の閲覧回数
atranzillo93
The number is
B361-6887-8BBF-ED12
Moreover, also for my collegue Anna D'Alessio:
E735-6A42-FED4-6005
Thank u so much.
Anita
6,176件の閲覧回数
mikedoidge
Both entitlements have been extended through 2025. Please use the activation code to re-activate your installations.
Mike
6,639件の閲覧回数
valeriaalessi
Good morning,
my license of S32DS for ARM 2018R1 IDE has expired. Could you please extend it for me?
In attachment you can find the current licence expired.
Thanks a lot.
Valeria
6,435件の閲覧回数
mikedoidge
Hello @valeriaalessi,
I checked the license server. It reported that you had exceeded the maximum number of returns. I have reset the return count. The issue should now be resolved. Please try once more.
Mike
6,400件の閲覧回数
valeriaalessi
Good morning,
I tried to re-activate with the same license number but it continues to tell me that the license is for another feature. However, the second error about exceeded number of returns does not come out again, after the first one.
Could you help me?
Thanks a lot.
Valeria
6,372件の閲覧回数
mikedoidge
I have manually returned the license from the server side. When you receive the offer to return the license, please choose 'Yes'. Sometimes there is some setting which does not get reset properly and this will force it to be reset. After this, and with my action to return the license, you should be able to activate without issue.
Mike
6,353件の閲覧回数
valeriaalessi
Good morning!
The issue is solved!
Thanks a lot.
Valeria
6,419件の閲覧回数
mikedoidge
I have extended your license through 2025. Please refresh from the Help->NXP Licenses menu or reactivate using the same activation code as before.
Mike
6,379件の閲覧回数
valeriaalessi
Good morning,
I tried to activate again the license, with the same number as before, but it tells me that the license is for another feature. Then, if I click on return, a error message appears (see attachments).
Could you help me please?
Thanks a lot!
15,598件の閲覧回数
mikedoidge
Mike
437件の閲覧回数
yinshi
My S32 Design Studio for ARM v2018 R1 License has already expired,could you help to extend it?Thanks! Activation Code: 98DE-149D-9787-5AF9
657件の閲覧回数
csuiil
Hi:
Thanks.
Item DescriptionS32 Design Studio
Order NumberS32DS_2018_R1_100931407
Purchase Order Number
Total Number of Licenses:100
Activation Code  C625-7579-0C28-63DC
License Applicable to Product(s):
Version Description
R1 2018 S32 Design Studio (View EULA) 3.1 S32 Design Studio (View EULA)
100 Available
2,527件の閲覧回数
HoganLiu
Dear,
Activation Code: E03E-A0CC-D45D-88C8
Thanks a lot
2,639件の閲覧回数
liamtsen
The number is
Thanks a lot.
タグ(1)
