S32DS IDE: CMake project Debug
ソリューションへジャンプ
9,170件の閲覧回数
Bruce_Ye
hello,
I am using cmake+nijia to create ELF files instead of S32DS IDE. The target development board is S32K344, and the compiler is GHS.
I have successfully generated ELF files so far, but when using PE for ELF file debugging, it does not work as expected, such as the Step over and Step return functions.
Here is the CMake project configuration I am using
***********************************CompileCfg.cmake**************************************
# Basic Settings
set(CMAKE_SYSTEM_NAME Generic)
set(CMAKE_SYSTEM_PROCESSOR ARM)
# Set up compiler
set(CMAKE_ASM_COMPILER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_C_COMPILER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_LINKER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_AR "D:/D/tools/ghs/comp_202114/ccarm.exe")
# Set compilation link options
set(C_OPTIONS "-preprocess_assembly_files -c99 --gnu_asm -g -dwarf2 -Onone -DSTART_FROM_FLASH -DS32K3XX -DENABLE_FPU -DLTC_ISOFT_CUSTOM -DINIT_STDBY_RAM -DARMCM7_SP -D__ITCM_INIT -D__DTCM_INIT -D__ghs__  -DGEELY_SPECIFICATION_USED=1 -DDISABLE_MCAL_INTERMODULE_ASR_CHECK -DBTB_ENABLE -DUSING_OS_AUTOSAROS -DS32K344 -DGHS -cpu=cortexm7 -fsingle -thumb -MD")
set(ASM_OPTIONS ${C_OPTIONS})
set(LD_OPTIONS "--gnu_asm -g -dwarf2 -nostartfiles -cpu=cortexm7 -thumb")
set(CMAKE_C_FLAGS ${C_OPTIONS})
set(CMAKE_ASM_FLAGS ${ASM_OPTIONS})
set(CMAKE_EXE_LINKER_FLAGS ${LD_OPTIONS})
set(CMAKE_TRY_COMPILE_PLATFORM_VARIABLES CMAKE_C_FLAGS CMAKE_ASM_FLAGS)
set(CMAKE_FIND_ROOT_PATH ${BINUTILS_PATH})
set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
******************************************CMakeLists.txt***********************************************
set(target_name "S32K344")
# Contains compile link configuration/lookup function cmake file
include(./CompileCfg.cmake)
include(./Function.cmake)
cmake_minimum_required(VERSION 3.5 FATAL_ERROR)
# Set project name and language
project(${target_name}_prj LANGUAGES C ASM)
# Set C language standard
set(CMAKE_C_STANDARD 99) # C99标准
set(CMAKE_C_EXTENSIONS ON) # 开启扩展,开启编译器特有扩展
set(CMAKE_C_STANDARD_REQUIRED ON) #强制指定标准
# Set engineering/OS src path
set(OS_SRC_DIR "${CA_DIR}/01_ProductCode/RTOS")
set(PRJ_SRC_DIR "${CA_DIR}/02_ProjectCode/00_OS_Project/${target_name}_CMake/src")
# Set link script file
set(LINK_SCRIPTS
    --gnu_asm
    -g
    -dwarf2
    -T "../src/McalLib/Mcal_lib/Platform_TS_T40D34M10I0R0/build_files/ghs/linker_flash_s32k344.ld"
    -e Reset_Handler
    -nostartfiles
    -cpu=cortexm7
    -thumb
# Set CommmonInclude header file directory
set(PRJ_COMMMONINCLUDE_INCS "${PRJ_SRC_DIR}/CommmonInclude")
# Contains cmake files corresponding to each module
include(${OS_SRC_DIR}/Os.cmake)
include(${PRJ_SRC_DIR}/McalLib/Mcal.cmake)
include(${PRJ_SRC_DIR}/Generate/Generate.cmake)
# Project Add Header File Dependency
include_directories(${PRJ_COMMMONINCLUDE_INCS} ${PRJ_GENERATE_INCS} ${BSW_OS_INCS} ${PRJ_SOURCE_INCS})
# get_property(dirs DIRECTORY ${CMAKE_SOURCE_DIR} PROPERTY INCLUDE_DIRECTORIES)
# message(">>> include_dirs=${dirs}")
# Set output file
set(EXECUTABLE ${target_name}.elf CACHE INTERNAL "TARGET")
# Obtain user files and build them
file(GLOB PRJ_MAIN_SRCS "${PRJ_SRC_DIR}/*.c")
add_executable(${EXECUTABLE} ${PRJ_MAIN_SRCS})
# Introduce subdirectories and build them
target_sources(${EXECUTABLE} PUBLIC ${PRJ_MCAL_SRCS})
target_sources(${EXECUTABLE} PUBLIC ${PRJ_GENERATE_SRCS})
target_sources(${EXECUTABLE} PUBLIC ${BSW_OS_SRCS})
# Special processing of assembly files
list(APPEND CMAKE_ASM_SOURCE_FILE_EXTENSIONS S asm inc)
set(MCAL_ASM_PATH "${PRJ_SRC_DIR}/McalLib/Mcal_lib/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs")
set(SAM_OBJ "${OS_SRC_DIR}/Platform/S32K3/S32K344/Arch_PendSV.s" "${MCAL_ASM_PATH}/startup_cm7.s" "${MCAL_ASM_PATH}/Vector_Table.s")
SET_SOURCE_FILES_PROPERTIES(${SAM_OBJ} PROPERTIES LANGUAGE ASM)
target_sources(${EXECUTABLE} PUBLIC ${SAM_OBJ})
# Link Options
target_link_options(${EXECUTABLE} PRIVATE  ${LINK_SCRIPTS})
How to use IDE debugging correctly,
Kind Regards.
8,985件の閲覧回数
stanish
This issue is probably related to a known issue listed in the S32DS release notes:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/S32-Design-Studio-for-S32-Platform-v3-...
Step out work incorrect with dbg_derived_types source: The GHS toolchain does not
generate DWARF Call Frame information that is suitable for unwinding the call stack. For
third-party debuggers incapable of unwinding the call stack through an alternate means
(disassembling code), this may nullify the ability to walk the call stack or view variables saved
in previous frames. As a workaround S32DS removes the debug frames info to force GDB client
to recreate the frames. In some cases this method may not work and lead to incorrect behaviour
for Step out command.
Workaround: Set a breakpoint at function end and run to breakpoint
Similar issue was pressent in S32DS for arm/power:
Problems could be experienced while debugging of elf file generated by GHS compiler like
missing call stack information, incorrect info on step into function, etc.
Workaround: On occasion GHS generates GDB incompatible debug information preventing the
debugger from displaying the call stack. In some cases, without such information gdb can still
debug your program. The program build needs to be augmented with a post-build step, select the
project in the project explorer view and File->Properties to display the project properties, under
C/C++ Build -> Settings select the build steps tab and enter the command gstrip –
r=.debug_frame executable. Switch to Instruction Stepping Mode to be able to step through
function. If this workaround does not help – please report issue to GreenHills support.
Hope it helps.
Stan
4 返答(返信)
5,599件の閲覧回数
kdscrr
@Bruce_Ye  hello, may I ask you a question?
how to import the source code into the S32DS ide?
when I import the elf which is generated by ghs into S32DS, but when I download the elf into MCU, I can not see the source code , only see the assembly code?
thanks
9,168件の閲覧回数
Bruce_Ye
The following is the engineering log of IDE using the GHS compiler:
Finished building: ../src/main.c
Building file: ../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c
Invoking: GHS C Compiler for ARM Standalone
ccarm -preprocess_assembly_files -c99 --gnu_asm -g -dwarf2 -Onone -DSTART_FROM_FLASH -DS32K3XX -DENABLE_FPU -DLTC_ISOFT_CUSTOM -DINIT_STDBY_RAM -DARMCM7_SP -D__ITCM_INIT -D__DTCM_INIT -D__ghs__ -DGEELY_SPECIFICATION_USED=1 -DDISABLE_MCAL_INTERMODULE_ASR_CHECK -DBTB_ENABLE -DUSING_OS_AUTOSAROS -DS32K344 -DGHS -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Extend" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\CommonInclude" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Kernel" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Platform" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\BSW_Config" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\header" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\build_files" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\build_files\ghs" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src\m7" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src\m7\ghs" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config\src" -cpu=cortexm7 -fsingle -thumb -MD -c -o "Projectcode/Mcal_config/src/Clock_Ip_Cfg.o" "../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c"
"D:\D\workpalce\S32k344\S32K344_DEMO_20\Platform\Arch_Define.h", line 66: warning #1-D:
last line of file ends without a newline
/*=======[E N D O F F I L E]==============================================*/
Finished building: ../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c
Building target: S32K344_DEMO_20.elf
Invoking: GHS C Linker for ARM Standalone
ccarm --gnu_asm -g -dwarf2 -T "D:/D/workpalce/S32k344/S32K344_DEMO_20/Projectcode/Mcal/Platform_TS_T40D34M10I0R0/build_files/ghs/linker_flash_s32k344.ld" -e Reset_Handler -nostartfiles -cpu=cortexm7 -thumb -o "S32K344_DEMO_20.elf" ./src/main.o ./Projectcode/Mcal_config/src/Clock_Ip_Cfg.o ./Projectcode/Mcal_config/src/Clock_Ip_PBcfg.o ./Projectcode/Mcal_config/src/IntCtrl_Ip_Cfg.o ./Projectcode/Mcal_config/src/Mcu_Cfg.o ./Projectcode/Mcal_config/src/Mcu_PBcfg.o ./Projectcode/Mcal_config/src/OsIf_Cfg.o ./Projectcode/Mcal_config/src/Platform_Cfg.o ./Projectcode/Mcal_config/src/Platform_Ipw_Cfg.o ./Projectcode/Mcal_config/src/Power_Ip_Cfg.o ./Projectcode/Mcal_config/src/Power_Ip_PBcfg.o ./Projectcode/Mcal_config/src/Ram_Ip_Cfg.o ./Projectcode/Mcal_config/src/Ram_Ip_PBcfg.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Adc.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Can.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Crc.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Crypto.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Dio.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Eth.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_EthSwt_43_SJA11XX.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_EthTrcv_43_PHY.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Fee.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Fls.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Gpt.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_I2c.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_I3c.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Icu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Iseled.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Lin.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Mcl.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Mcu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Ocu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Port.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Pwm.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Rm.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sai.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sbc_fs26.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sbc_fs86.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sent.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Spi.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Uart.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg_43_fs26.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg_43_fs86.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs/Vector_Table.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs/startup_cm7.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/exceptions.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/startup.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/nvic.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/sys_init.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/system.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/IntCtrl_Ip.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/Platform.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/Platform_Ipw.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/System_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Data.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Divider.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_DividerTrigger.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_ExtOsc.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_FracDiv.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Frequency.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Gate.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_IntOsc.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Monitor.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Pll.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_ProgFreqSwitch.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Selector.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Specific.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu_Dem_Wrapper.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu_Ipw.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_CortexM7.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_FLASH.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_ME.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_RGM.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_RGM_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_PMC.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_PMC_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_Private.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Ram_Ip.o ./Projectcode/Mcal/Det_TS_T40D34M10I0R0/src/Det.o ./Projectcode/Mcal/Det_TS_T40D34M10I0R0/src/Det_stub.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer_System.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer_System_Internal_Systick.o ./Projectcode/BSW_Config/Os_Cfg.o ./Projectcode/BSW_Config/Os_Intvet.o ./Projectcode/BSW_Config/Os_Kdata.o ./Projectcode/BSW_Config/Os_UserInf.o ./Platform/Arch_Extend.o ./Platform/Arch_Irq.o ./Platform/Arch_Mpu.o ./Platform/Arch_PendSV.o ./Platform/Arch_Processor.o ./Platform/Arch_Timer.o ./Platform/Arch_Trap.o ./Kernel/Os_Alarm.o ./Kernel/Os_Appl.o ./Kernel/Os_Core.o ./Kernel/Os_Counter.o ./Kernel/Os_Event.o ./Kernel/Os_Hook.o ./Kernel/Os_Interrupt.o ./Kernel/Os_Ioc.o ./Kernel/Os_Kernel.o ./Kernel/Os_Mprot.o ./Kernel/Os_Panic.o ./Kernel/Os_Peripheral.o ./Kernel/Os_Resource.o ./Kernel/Os_Rpc.o ./Kernel/Os_ScheduleTable.o ./Kernel/Os_Spinlock.o ./Kernel/Os_Sprot.o ./Kernel/Os_StackMonitor.o ./Kernel/Os_Task.o ./Kernel/Os_Tprot.o ./Extend/Os_Extend.o
Finished building target: S32K344_DEMO_20.elf
8,986件の閲覧回数
stanish
Hope it helps.
Stan
8,968件の閲覧回数
Bruce_Ye
Thank you for your help.
"Problems could be experienced while debugging of elf file generated by GHS compiler like
missing call stack information, incorrect info on step into function, etc.". It is indeed here that caused the problem. I encountered the same issue during debugging when deleting gstrip - r=. debug_frame ${ProjName}. elf in the S32DS compiled project.
Next, I need to add relevant commands to my CMakeLists.txt. I hope everything goes smoothly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1789405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32DS%20IDEs%3A%20CMake%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1789405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20S32DS%20IDEs%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20cmake%2Bnijia%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ELF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AF%BE%E8%B1%A1%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AFS32K344%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AFGHS%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%20ELF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%94%9F%E6%88%90%E3%81%AB%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ELF%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%20PE%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%82%84%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%83%AA%E3%82%BF%E3%83%BC%E3%83%B3%E6%A9%9F%E8%83%BD%E3%81%AA%E3%81%A9%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_0-1705396720058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_0-1705396720058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258351iB474A20F56F0BCE1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_0-1705396720058.png%22%20alt%3D%22Bruce_Ye_0-1705396720058.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BCMake%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E**********************************CompileCfg.cmake****************************************%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%23%20%E5%9F%BA%E6%9C%AC%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_SYSTEM_NAME%20%E6%B1%8E%E7%94%A8)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_SYSTEM_PROCESSOR%20ARM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(CMAKE_ASM_COMPILER%3C%2FSPAN%3E%20%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(CMAKE_C_COMPILER%3C%2FSPAN%3E%20%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(CMAKE_LINKER%3C%2FSPAN%3E%20%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3ECMAKE_AR%3C%2FSPAN%3E%20%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(C_OPTIONS%3C%2FSPAN%3E%20%3CSPAN%3E%22-preprocess_assembly_files%20-c99%20--gnu_asm%20-g%20-dwarf2%20-Onone%20-DSTART_FROM_FLASH%20-DS32K3XX%20-DENABLE_FPU%20-DLTC_ISOFT_CUSTOM%20-DINIT_STDBY_RAM%20-DARMCM7_SP%20-D__ITCM_INIT%20-D__DTCM_INIT%20-D%20__ghs__%20-DGEELY_SPECIFICATION_USED%3D1%20-DDISABLE_MCAL_INTERMODULE_ASR_CHECK%20-DBTB_ENABLE%20-DUSING_OS_AUTOSAROS%20-DS32K344%20-DGHS%20-cpu%3Dcortexm7%20-fsingle%20-thumb%20-MD%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(ASM_OPTIONS%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BC_OPTIONS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(LD_OPTIONS%3C%2FSPAN%3E%20%3CSPAN%3E%22--gnu_asm%20-g%20-dwarf2%20-nostartfiles%20-cpu%3Dcortexm7%20-thumb%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_FLAGS%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BC_OPTIONS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_ASM_FLAGS%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BASM_OPTIONS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3ECMAKE_EXE_LINKER_FLAGS%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BLD_OPTIONS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_TRY_COMPILE_PLATFORM_VARIABLES%20CMAKE_C_FLAGS%20CMAKE_ASM_FLAGS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BBINUTILS_PATH%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM%20NEVER)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88CMAKE_FIND_ROOT_PATH_MODE_LIBRARY%E3%81%AE%E3%81%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88CMAKE_FIND_ROOT_PATH_MODE_INCLUDE%E3%81%AE%E3%81%BF%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E**********************************************CMakeLists.txt****************************************************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%EF%BC%88%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%90%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CS32K344%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%AA%E3%83%B3%E3%82%AF%E8%A8%AD%E5%AE%9A%2F%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E9%96%A2%E6%95%B0%E3%81%AEcmake%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E(.%2FCompileCfg.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E(.%2FFunction.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecmake_minimum_required%3C%2FSPAN%3E%20%3CSPAN%3E(%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.5%20FATAL_ERROR)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%90%8D%E3%81%A8%E8%A8%80%E8%AA%9E%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7Btarget_name%7D%3C%2FSPAN%3E%20%3CSPAN%3E_prj%20%E8%A8%80%E8%AA%9E%20C%20ASM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20C%E8%A8%80%E8%AA%9E%E6%A8%99%E6%BA%96%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%20%3CSPAN%3E(CMAKE_C_STANDARD%2099)%3C%2FSPAN%3E%20%3CSPAN%3E%23%20C99%E6%A0%87%E6%BA%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%20%3CSPAN%3E(CMAKE_C_EXTENSIONS%3C%2FSPAN%3E%20%3CSPAN%3EON%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%23%20%E5%BC%80%E5%90%AF%E6%89%A9%E5%B1%95%E3%80%81%E5%BC%80%E5%90%AF%E7%BC%96%E8%AF%91%E5%99%A8%E5%9B%BA%E6%9C%89%E6%89%A9%E5%B1%95%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%20%3CSPAN%3E(CMAKE_C_STANDARD_REQUIRED%3C%2FSPAN%3E%20%3CSPAN%3EON%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%23%E5%BC%BA%E5%88%B6%E6%8C%87%E5%AE%9A%E6%A0%87%E6%BA%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%2FOS%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%91%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%20%3CSPAN%3E(OS_SRC_DIR%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BCA_DIR%7D%20%2F01_ProductCode%2FRTOS%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(PRJ_SRC_DIR%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BCA_DIR%7D%20%2F02_ProjectCode%2F00_OS_Project%2F%20%24%7Btarget_name%7D%20_CMake%2Fsrc%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(LINK_SCRIPTS%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E--gnu_asm%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-g%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%E3%83%89%E3%83%AF%E3%83%BC%E3%83%952%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-T%3C%2FSPAN%3E%20%3CSPAN%3E%22..%2Fsrc%2FMcalLib%2FMcal_lib%2FPlatform_TS_T40D34M10I0R0%2Fbuild_files%2Fghs%2Flinker_flash_s32k344.ld%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-e%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-nostartfiles%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-cpu%3Dcortexm7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-%E8%A6%AA%E6%8C%87%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20CommmonInclude%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%20%3CSPAN%3E(PRJ_COMMMONINCLUDE_INCS%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BPRJ_SRC_DIR%7D%20%2FCommmonInclude%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E5%90%84%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8Bcmake%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BOS_SRC_DIR%7D%3C%2FSPAN%3E%20%3CSPAN%3E%2FOs.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_SRC_DIR%7D%3C%2FSPAN%3E%20%3CSPAN%3E%2FMcalLib%2FMcal.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_SRC_DIR%7D%3C%2FSPAN%3E%20%3CSPAN%3E%2FGenerate%2FGenerate.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude_directories%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_COMMMONINCLUDE_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_GENERATE_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BBSW_OS_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_SOURCE_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%20get_property(dirs%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%24%7BCMAKE_SOURCE_DIR%7D%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%20INCLUDE_DIRECTORIES)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8(%22%26gt%3B%26gt%3B%26gt%3B%20include_dirs%3D%20%24%7Bdirs%7D%20%22)%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E5%87%BA%E5%8A%9B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E%24%7Btarget_name%7D%3C%2FSPAN%3E%20%3CSPAN%3E.elf%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSPAN%3E%3CSPAN%3E%E5%86%85%E9%83%A8%3C%2FSPAN%3E%3CSPAN%3E%22TARGET%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3CSPAN%3E(GLOB%20PRJ_MAIN_SRCS%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BPRJ_SRC_DIR%7D%20%2F*.c%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_MAIN_SRCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%B5%E3%83%96%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E5%B0%8E%E5%85%A5%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_MCAL_SRCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_GENERATE_SRCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3CSPAN%3E%24%7BBSW_OS_SRCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E7%89%B9%E6%AE%8A%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%AA%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E(APPEND%20CMAKE_ASM_SOURCE_FILE_EXTENSIONS%20S%20asm%20inc)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3CSPAN%3E(MCAL_ASM_PATH%3C%2FSPAN%3E%20%3CSPAN%3E%22%20%24%7BPRJ_SRC_DIR%7D%20%2FMcalLib%2FMcal_lib%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(SAM_OBJ%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BOS_SRC_DIR%7D%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FS32K3%2FS32K344%2FArch_PendSV.s%22%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%20%24%7BMCAL_ASM_PATH%7D%20%2Fstartup_cm7.s%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8C%20%24%7BMCAL_ASM_PATH%7D%20%2FVector_Table.s%E3%80%8D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESET_SOURCE_FILES_PROPERTIES%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BSAM_OBJ%7D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E8%A8%80%E8%AA%9E%20ASM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%91%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%3C%2FSPAN%3E%3CSPAN%3E%24%7BSAM_OBJ%7D%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_link_options(%20%24%7BEXECUTABLE%7D%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%24%7BLINK_SCRIPTS%7D%20)%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E**************************************************************************************************************************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EIDEs%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%95%AC%E5%85%B7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228205%22%20target%3D%22_blank%22%3E%40Bruce_Ye%3C%2FA%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%A6%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92S32DS%20IDE%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%20ghs%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20elf%20%E3%82%92%20S32DS%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81elf%20%E3%82%92%20MCU%20%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AA%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1819430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1819430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%22%3CSPAN%3EGHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9Felf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E6%83%85%E5%A0%B1%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E9%96%A2%E6%95%B0%E3%81%B8%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E6%99%82%E3%81%AB%E6%83%85%E5%A0%B1%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%80%81%E3%81%AA%E3%81%A9%E3%80%82%22%E3%80%82%E3%81%BE%E3%81%95%E3%81%AB%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82S32DS%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%B8%88%E3%81%BF%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%20gstrip%20-%20r%3D.%20debug_frame%20%24%7BProjName%7D%20.%20elf%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AB%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81CMakeLists.txt%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E9%A0%86%E8%AA%BF%E3%81%AB%E9%80%B2%E3%82%80%E3%81%93%E3%81%A8%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81S32DS%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-for-S32-Platform-v3-4-Windows-Linux-released%2Fta-p%2F1206337%3Fattachment-id%3D107423%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-for-S32-Platform-v3-4-Windows-Linux-released%2Fta-p%2F1206337%3Fattachment-id%3D107423%3C%2FA%3E%3C%2FP%3E%3CP%3Edbg_derived_types%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A2%E3%82%A6%E3%83%88%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%3A%20GHS%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%81%AF%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%82%A2%E3%83%B3%E3%83%AF%E3%82%A4%E3%83%B3%E3%83%89%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%20DWARF%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%83%85%E5%A0%B1%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%3CBR%20%2F%3E%E4%BB%A3%E6%9B%BF%E6%89%8B%E6%AE%B5%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E5%B7%BB%E3%81%8D%E6%88%BB%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%B5%E3%83%BC%E3%83%89%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%3CBR%20%2F%3E%EF%BC%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%80%86%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AB%E3%81%99%E3%82%8B%EF%BC%89%E3%81%A8%E3%80%81%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E3%81%9F%E3%81%A9%E3%81%A3%E3%81%9F%E3%82%8A%E3%80%81%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E5%A4%89%E6%95%B0%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%89%8D%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%A7%E3%80%82%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81S32DS%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E6%83%85%E5%A0%B1%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6GDB%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E5%BC%B7%E5%88%B6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E5%86%8D%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CASE%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%9B%E3%81%9A%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%9F%E5%8B%95%E4%BD%9C%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A2%E3%82%A6%E3%83%88%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E5%9B%9E%E9%81%BF%E7%AD%96%3C%2FSTRONG%3E%3A%20%E9%96%A2%E6%95%B0%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%BE%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3ES32DS%20%E3%81%AE%20ARM%2FPOWER%20%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EGHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9Felf%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E6%83%85%E5%A0%B1%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E9%96%A2%E6%95%B0%E3%81%B8%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AA%E3%81%A9%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E5%9B%9E%E9%81%BF%E7%AD%96%3C%2FSTRONG%3E%3A%20GHS%E3%81%AFGDB%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%AA%E3%81%84%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%83%85%E5%A0%B1%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%AB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CASE%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82GDB%E3%81%AF%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E5%BE%8C%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%97%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%93%E3%83%A5%E3%83%BC%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB-%26gt%3B%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20C%2FC%2B%2B%E3%83%93%E3%83%AB%E3%83%89%20-%26gt%3B%20%E8%A8%AD%E5%AE%9A%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%BF%E3%83%96%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89gstrip%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20r%3D.debug_frame%20%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E5%91%BD%E4%BB%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%E3%80%82%E3%81%93%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%9F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81GreenHills%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1789409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1789409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AFGHS%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FIDEs%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E******************************************************************************%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E5%AE%8C%E4%BA%86%3A%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20Arm%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E7%94%A8%20GHS%20C%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Eccarm%20-preprocess_assembly_files%20-c99%20--gnu_asm%20-g%20-dwarf2%20-Onone%20-DSTART_FROM_FLASH%20-DS32K3XX%20-DENABLE_FPU%20-DLTC_ISOFT_CUSTOM%20-DINIT_STDBY_RAM%20-DARMCM7_SP%20-D__ITCM_INIT%20-D__DTCM_INIT%20-D%20__ghs__%20-DGEELY_SPECIFICATION_USED%3D1%20-DDISABLE_MCAL_INTERMODULE_ASR_CHECK%20-DBTB_ENABLE%20-DUSING_OS_AUTOSAROS%20-DS32K344%20-DGHS%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CExtend%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CCommonInclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CKernel%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5C%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%5CBSW_Config%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%5CMcal%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Cheader%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cbuild_files%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cbuild_files%5Cghs%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%5Cm7%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%5Cm7%5Cghs%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%5Csrc%22%20-cpu%3Dcortexm7%20-fsingle%20-thumb%20-MD%20-c%20-o%20%22Projectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.o%22%E3%80%8C..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%E3%80%8D%3CBR%20%2F%3E%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5C%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%5CArch_Define.h%22%2C%E8%A1%8C66%3A%20%E8%AD%A6%E5%91%8A%20%231-D%3A%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E8%A1%8C%E3%81%AF%E6%94%B9%E8%A1%8C%E3%81%AA%E3%81%97%E3%81%A7%E7%B5%82%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%2F*%3D%3D%3D%3D%3D%3D%3D%5BENDOFFILE%5D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3CBR%20%2F%3E%20%5E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%3C%2FP%3E%3CP%3E************************************************************************************************%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3A%20S32K344_DEMO_20.elf%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%20ARM%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E7%94%A8%20GHS%20C%20%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%3CBR%20%2F%3Eccarm%20--gnu_asm%20-g%20-dwarf2%20-T%20%22D%3A%2FD%2Fworkpalce%2FS32k344%2FS32K344_DEMO_20%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fbuild_files%2Fghs%2Flinker_flash_s32k344.ld%22-e%20Reset_Handler%20-nostartfiles%20-cpu%3Dcortexm7%20-thumb%20-o%20%22S32K344_DEMO_20.elf%22.%2Fsrc%2Fmain.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FIntCtrl_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FMCU_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FMCU_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FOsIf_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_Ipw_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPower_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPower_Ip_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FRam_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FRam_Ip_PBcfg.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Adc.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Can.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Crc.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Crypto.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Dio.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Eth.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_EthSwt_43_SJA11XX.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_EthTrcv_43_PHY.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Fee.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Fls.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Gpt.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_I2c.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_I3c.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Icu.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Iseled.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Lin.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Mcl.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_MCU.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Ocu.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Port.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Pwm.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Rm.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sai.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sbc_fs26.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sbc_fs86.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sent.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Spi.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Uart.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg_43_fs26.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg_43_fs86.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%2FVector_Table.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%2Fstartup_cm7.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fexceptions.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fstartup.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fnvic.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fsys_init.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fsystem.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fsrc%2FIntCtrl_Ip.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fsrc%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fsrc%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_Ipw.o%20.%2FProjectcode%2FMcal%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0_TS_T40D34M10I0R0%2Fsrc%2FSystem_Ip.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Data.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Divider.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_DividerTrigger.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_ExtOsc.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_FracDiv.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Frequency.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Gate.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_IntOsc.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Irq.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Monitor.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Pll.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_ProgFreqSwitch.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Selector.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Specific.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FMCU.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FMcu_Dem_Wrapper.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FMcu_Ipw.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_CortexM7.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_FLASH.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_ME.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_RGM.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_RGM_Irq.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_PMC.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_PMC_Irq.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_Private.o%20.%2FProjectcode%2FMcal%2FMCU_TS_T40D34M10I0R0%2Fsrc%2FRam_Ip.o%20.%2FProjectcode%2FMcal%2FDet_TS_T40D34M10I0R0%2Fsrc%2FDet.o%20.%2FProjectcode%2FMcal%2FDet_TS_T40D34M10I0R0%2Fsrc%2FDet_stub.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer_System.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer_System_Internal_Systick.o%20.%2FProjectcode%2FBSW_Config%2FOs_Cfg.o%20.%2FProjectcode%2FBSW_Config%2FOs_Intvet.o%20.%2FProjectcode%2FBSW_Config%2FOs_Kdata.o%20.%2FProjectcode%2FBSW_Config%2FOs_UserInf.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Extend.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Irq.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Mpu.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_PendSV.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Processor.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Timer.o%20.%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2FArch_Trap.o%20.%2FKernel%2FOs_Alarm.o%20.%2FKernel%2FOs_Appl.o%20.%2FKernel%2FOs_Core.o%20.%2FKernel%2FOs_Counter.o%20.%2FKernel%2FOs_Event.o%20.%2FKernel%2FOs_Hook.o%20.%2FKernel%2FOs_Interrupt.o%20.%2FKernel%2FOs_Ioc.o%20.%2FKernel%2FOs_Kernel.o%20.%2FKernel%2FOs_Mprot.o%20.%2FKernel%2FOs_Panic.o%20.%2FKernel%2FOs_Peripheral.o%20.%2FKernel%2FOs_Resource.o%20.%2FKernel%2FOs_Rpc.o%20.%2FKernel%2FOs_ScheduleTable.o%20.%2FKernel%2FOs_Spinlock.o%20.%2FKernel%2FOs_Sprot.o%20.%2FKernel%2FOs_StackMonitor.o%20.%2FKernel%2FOs_Task.o%20.%2FKernel%2FOs_Tprot.o%20.%2FExtend%2FOs_Extend.o%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E5%AE%8C%E4%BA%86%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3A%20S32K344_DEMO_20.elf%3C%2FP%3E%3CP%3E**********************************************************************************************%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_0-1705398814437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_0-1705398814437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258365i2AA72B2EA6D5644B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_0-1705398814437.png%22%20alt%3D%22Bruce_Ye_0-1705398814437.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E**********************************************************************************************%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_1-1705398847049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_1-1705398847049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258366i46E3E3D3646BAC9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_1-1705398847049.png%22%20alt%3D%22Bruce_Ye_1-1705398847049.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
