S32DS_ARM_v2018.R1's examples project: KEA128/bootloader_KEA is not run after reset?
1,888 次查看
chenaimei15
Hi,why  S32DS_ARM_v2018.R1's examples project:  KEA128/bootloader_KEA is not run after reset?
标记 (1)
1,632 次查看
Robin_Shen
Hi may 王,
Sorry for my late reply!
I am not sure if you have following the steps in description.
The RAppID BL Tool can be download from here.
The rbf file is under the install folder of this tool .(C:\Freescale\RAppIDBL\RBF_Files)
Robin
1,632 次查看
chenaimei15
Hi  Robin:  Thank you for  your information。I  will learn to use the RAppID Boot Loader Utility  later。
