I am using S32DS 1.3 for ARM on S32K projects and would like to use IAR to do the compile and debug. Have tried to right click on the project and select export. However nothing happens when clicking the Finish button, no xml is generated.
Could you kindly help advise how I can generate the xml correctly?
Thanks!
Steve
Hi Stan,
I have installed IAR plugin into S32 Design Studio, I can't build and debug your project using IAR tools from S32 Design Studio Eclipse IDE.When I debug my project ,the debug window remains in S32DS.
And I want to debug my project in IAR,but this way has no effect.
Additions, I can't watch variables and expressions when the target is running In S32DS Debug window,
Can you give me some suggestions about this problem.
And I don't know how to create a project of S32K144 in IAR, Can you provide me some S32K144 demos In IAR environment.
Hunter
