S32DS 1.2 Clean does not clean
2,478件の閲覧回数
markpedley
I'm using S32DS v1.2 for PowerPC. The problem is that requesting a project clean does not delete object files and executables. Something somewhere has got confused. Has anyone else seen the problem and have any ideas how to fix it?
2 返答(返信)
2,227件の閲覧回数
stanish
Hi Mark,
thanks for the report!
This is a known issue logged as S32DS-4629.
Engineering team is currently working on the fix, which should be able in the next release/update.
Please delete the output directory to force your project rebuilding.
regards,
Stan
2,227件の閲覧回数
jiri_kral
I tested couple projects - and in my case are .o and .elf files deleted after clean. In your case - it is related to one particular project or for all of them? You can try to delete project's Debug directory. Other workaround may be create new workspace and import there your existing project.
Jiri
