S32CT for S32G LLCE CAN example
asap
hi experts,
is there a path using S32DS Configuration tool to enable the S32G LLCE CAN?
the current LLCE FW & driver examples are based on tresos tool. while we have plenty of customers are from non-AUTOSAR environment, it will be good to know if S32 CT can do the job for non-AUTOSAR user to build their own LLCE CAN use case (with RTOS or with bare metal code).
If the answer is yes, could you please point me to the right resources building this example?
thank you very much
Albert
yqlau
Hi ,Have you found the solution yet?
