S32 design Studio
S32 design Studio
dennisessenmach
I am trying to install S32 design studio v2.0. When I install S32 design studio v2.0 it send request.xml I take this file to license request for Activation.xml I store this on to my computer. When I get back to the install it has timeout and will not let me add the Activation.xml file. How do I do this is the time they allow?
jiri_kral
in your activation request is missing Unique Machine ID. Without this ID the S32DS can't be activated. Your very first attempt on different PC machine contains such ID and the activation was ok.
The Missing machine UID often occurs when you are using Virtual Machine. In some cases the OS security policy block S32SD to obtain such ID from OS. You can try to backup content of c:\ProgramData\FLEXnet\ folder, delete it and try the installation again.
