S32 Installation Failure
3,008 次查看
bjrajendra
Senior Contributor I
Hello all,
I downloaded and installed the S32 Design studio with offline support. Unfortunately I updated S32DS_ARM_Win32_v2018 patches to my S32DS_ARM_Win32_v2.0 2017 version and then I can't able to create a new project because of this issue. Thus I uninstalled the S32DS and when I'm trying to reinstall the software it is showing "please select the another location to extract the installer to". The figure is shown below. I downloaded the latest version 2018 ARM, but when I'm trying to install the software it is showing same message as below.
Though I choose the different locations again & again, still it is showing the same message.
Note: The file was downloaded in 1 PC and copied to my PC where I'm trying to install it. Kindly suggest solution, as I'm running out of time.
BJ Rajendranath.
2,802 次查看
bjrajendra
Hello all,
For this please try to use the different drive ( i.e, C: or D : or E:) to extract and then you can later install all the necessary drives by giving necessary drive ( like we all know C: drive is used to store all installation file ).
Hope this solves the issue.
Raju
2,803 次查看
bjrajendra
Hello all,
Raju
