S32 Design studio for ARM 3.5 install fail
1,254 次查看
Ean
Originally, S32DS could be used normally. Perhaps due to reinstalling the system, when using it again, there was a prompt that the license missing.
Then I uninstalled and reinstalled it, and used the license received in the previous email to activate it online. However, the following problem occurred. When I installed it, I opened it in the administrator mode, but still could not solve the problem.
After entering the corresponding folder of the problem, running cllSvrUtility.exe still cannot run.
1,147 次查看
jiri_kral
you can try to backup and delete content of c:\ProgramData\FLEXnet\ folder. The folder is by default hidden.
Anyway, are you using the correct activation key? The right one ends with -2ECF
