Problems migrating projects from Codewarrior V10.6 to S32DS
1,410 次查看
juan_gonzalez
Hi to all,
i'm trying to migrate codewarrior projects to S32DS but different problems arise. During debuggin when i run the project this message appear:
Another problem is that the definitions can not be used:
How can these problems be solved?
1,366 次查看
martin_kovar
I have already contacted you via internal case, so please continue using one of the email you received from me. In case your project is not confidential and you would like to share it at NXP community, we can continue here.
Thank you for understanding.
Martin
