Prevent S32 from building
1,673 次查看
cholland
Contributor V
I was wondering how to disable build from S32 Design Studio.
I am using an external make outside of the S32 environment.
So, I just want to use S32 for debugging purposes.
I keep getting the error "Program 'make' not found in PATH".
So, I want to disable build.
Thank you
1,556 次查看
alexanderfedoto
Have you tried to disable it in "Debug configurations" for corresponding debug profile -> "Build (if required) before launching -> Disable auto build" ?
