Preparation or Config: Library files made by the Wind River compiler diab to be used by GCC
2,881 次查看
lizhichaosdut
I want to use the .a file generated by WindRiver complier dcc in the gcc environment,how to config the dcc?
标记 (4)
4 回复数
2,839 次查看
jiri_kral
if you like to use your library archive with gcc, you need to build the library with gcc,
2,832 次查看
lizhichaosdut
The problem is my supplyer used Wind river
my company don't have.is there a common protocol called EABI.And if both obey that .The problem will be solved? I don t know enough
2,818 次查看
jiri_kral
unfortunately this approach is not possible. These two compilers aren't compatible.
2,810 次查看
lizhichaosdut
OK,thank!
