Preparation or Config: Library files made by the Wind River compiler diab to be used by GCC
lizhichaosdut
I want to use the .a file generated by WindRiver complier dcc in the gcc environment,how to config the dcc?
Tags (4)
jiri_kral
if you like to use your library archive with gcc, you need to build the library with gcc,
lizhichaosdut
The problem is my supplyer used Wind river
my company don't have.is there a common protocol called EABI.And if both obey that .The problem will be solved? I don t know enough
jiri_kral
unfortunately this approach is not possible. These two compilers aren't compatible.
lizhichaosdut
OK,thank!
