PowerPC MPC5744P simulator using S32DS
1,323 次查看
NNRuss
I wish to use a virtual debugger that simulates a connection to a MPC5744P MCU. Then, I can step debug without having physical hardware and do everything virtually in S32DS.
Is there such SDK or simulator that will allow me to run my code without physical hardware?
Thank you.
1,315 次查看
lukaszadrapa
Hi Nathan,
I'm afraid the answer is no, there's no such simulator. Long time ago, I can remember there was a simulator for old 16bit S12 devices which I used sometimes for simple tests. But there's nothing like that for MPC5 devices.
Lukas
