No info in components in S32 Design Studio
3,245件の閲覧回数
nanjun
I opened this example LPUART_s32k144 in S32 Design Studio for Arm version 1.0 , there is no infomation for pin configuration listed in "components" menu shown here. Is this supported by processor expert? how can I do further graphic configuration here? Thanks.
Kind regards,
Nanjun
3,238件の閲覧回数
lukaszadrapa
Hi Nanjun,
it's a project where the SDK is not used. So, no components are visible. It looks like example from AN5413 - all these examples are bareboard projects.
By the way, I can see you use older version of S32DS. The latest one is 3.4:
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
And the latest SDK is RTM 4.0.2.
It's highly recommended to use the latest ones.
Lukas
3,239件の閲覧回数
lukaszadrapa
Hi Nanjun,
Lukas
3,183件の閲覧回数
nanjun
Hello Lukas,
thanks for your advice!
Kind regards,
Nanjun
