Need LNA Help
Need LNA Help
1,572件の閲覧回数
Dogman
How do I get the 0-30mhz gain, noise figure, 1db  compression, and similar specs for thsse general purpose chips:  The datasheets seem to stop below 100mhz.  Here are the chip model numbers I need help on for the 1-30mhz range: BGU6104, BGU7003W, and BGA2869.   Or if you  recommend a different LNA for better low noise specs at these freqs, please let me know.
0 返答(返信)
