MPC5748G-FREERTOS
已解决
MPC5748G-FREERTOS
跳至解决方案
4,284 次查看
kalai
hi,
   we are using MPC5748g controller and s32DS IDE. i try to boot freertos in this board so please can you provide document
thanks
kalai
1 解答
4,277 次查看
jiri_kral
there is an Example (File -> New -> S32DS Project from Example) for FreeRTOS. Or what's your issue?
Jiri
在原帖中查看解决方案
4 回复数
4,254 次查看
kalai
hi jiri
i need to create own project without example code using freertos .can you provide document ?
thanks
kalai
4,245 次查看
jiri_kral
Hi Kalai,
FreeRTOS is SDK component. Just create new project based on SDK and add FreeRTOS component into your project.
SDK documentation is (with default install path) in folder:
c:\NXP\S32DS_Power_v2.1\S32DS\software\S32_SDK_S32PA_RTM_3.0.3\doc\
FreeRTOS documentation you can find here:
https://www.freertos.org/FreeRTOS-quick-start-guide.html#page_top
Jiri
4,274 次查看
kalai
thanks
kalai
4,277 次查看
jiri_kral
Jiri
