Is it possible to replace ARM GCC toolchain by IAR toolchain for ARM in S32 DS?
1,442 次查看
samerbastawy
PS: I have the IAR license but I want to switch from building my project using ARM GCC, to IAR. Any suggestions?
标记 (3)
1,164 次查看
stanish
Hi Samer,
S32DS for ARM supports IAR eclipse plugin. This allows you to create and build the project with IAR Toolchain and also debug it using IAR C-SPY debug engine under S32DS Eclipse environment.
For more information about how to install and use IAR plugin see the post below:
https://community.nxp.com/thread/438558?commentID=931340#comment-851981
Hope it helps.
Stan
