Implement MPU by active or inactive Region Descriptor 1
ソリューションへジャンプ
3,071件の閲覧回数
hilverlee
For S32K118, does it have any side effect for implement MPU by active or inactive Region Descriptor 1 every 30 ms?
3,057件の閲覧回数
lukaszadrapa
Hi @hilverlee ,
this is not a problem, there are no side effects. You can enable/disable your descriptors as needed.
Lukas
4 返答(返信)
3,065件の閲覧回数
lukaszadrapa
there's no problem to dynamically change MPU descriptors, I can't see issues here.
Lukas
3,062件の閲覧回数
hilverlee
@lukaszadrapa
Thank you very much for your quick response.
But in order to double check, I highlight that our current software is not change the access permission by dynamic switching the MPU Region Descriptors (such is change Region Descriptor 0 to Region Descriptor 1), but change the valid or invalid attribute of Region Descriptor 1 by changing the corresponding region descriptor’s valid bit every 30 ms. Does it has any side effect?
3,058件の閲覧回数
lukaszadrapa
Hi @hilverlee ,
Lukas
3,019件の閲覧回数
hilverlee
@lukaszadrapa Got it. Thank you very much!
