IRQ handler in assembly
2,511件の閲覧回数
smruthi_ramesh
I have to write a custom IRQ handler for an FTM PWM overflow interrupt on the S32K148. How do I go about doing the same? Where can I find the vector table in assembly that calls the handlers defined in startup_S32k148.s?
タグ(4)
2,410件の閲覧回数
raresvasile
You can overwrite the handler using INT_SYS_InstallHandler(...).
Rares
