How to recompile SREC files
1,511 次查看
meepo
I use Inca to modify the data of SREC and regenerate an S19 file. How to recompile the S19 file with s32ds so that it can be swiped into the ECU
1,496 次查看
jiri_kral
the s-record is product of build (respectively of post build step). Please check if in your project properties is s-rec output enabled:
Jiri
