How to make a 'cnn_classifier.elf' on s32v234evb?
1,586 次查看
woong214
We are trying to make a cnn classfier.elf on vision sdk.
but we have some problems when we compile the example which is located in "~/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/demos/apps/cnn_classifier/build-v234ce-gnu-linux-d".
we make error below:
~/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk/demos/apps/cnn_classifier/build-v234ce-gnu-linux-d$ make
Current SDK ROOT is /home/Comuser/VisionSDK_S32V2_RTM_1_3_0/s32v234_sdk
make: *** No rule to make target '../../../../isp/graphs/mipi_simple/dynamic_mipi_simple/build-v234ce-gnu-linux-d/libdynamic_mipi_simple.a', needed by 'gdc_cnn.elf'. Stop.
And we don't know a "nBuild". What does 'nbuild' mean?
when we're trying to make 'libdynamic_mipi_simple.a' and go into 'nbuild' folder, we are not able to compile in 'nbuild' folder. There is no Makefile in 'nbuild' folder.
So we're wondering tha 'nBuild' means.
sincerely
hyoung woong.
标记 (2)
1 回复
1,471 次查看
jiri_kral
please try
make allsub
command instead make. This also builds libraries on which cnn_classifier depends.
Hope it helps.
Jiri
