How to change device package for existing project?
已解决
跳至解决方案
2,786 次查看
hns80
Senior Contributor I
Once a project is created in S32DS, how is it possible to change the device package?
For example, the i2c_HLD_Example_S32K148 uses the LQFP176 package. What if I want to use a smaller package, such as LQFP64? Where do I change this setting?
A similar question was asked and answered on the forum in 2018, but the software has changed a lot since then and the answer no longer applies.
1 解答
2,778 次查看
Robin_Shen
There is no LQFP64 S32K148, so you can not change the package to it. Since you did not mention the version of S32DS, it is assumed that you are using the latest version of S32 design studio for S32 platform 3.4.
Please change the package by using S32 Configuration Tool -> Switch package for the Processor
Robin
在原帖中查看解决方案
1 回复
2,779 次查看
Robin_Shen
Robin
