How are find or create *.elf file in project?
2,976件の閲覧回数
antonkarzanov
Hello.
I`m using sample project for SAC57D5H. S32 is displays problem (see attach pict.).
*.elf file does create is S32 or I have to manual create it?
What settings should I set for generate *.elf file?
タグ(3)
2,816件の閲覧回数
martin_kovar
there is some linking problem in your project which does not allow to create elf file. At first, you must remove the errors and then elf file will be created.
Martin
