How To Solve The Build Errors about Create New Project from Example ‘RSDK_S32DS_template’
4,394件の閲覧回数
jone_yang
HI,
   I follow the Step:"HOWTO: Create New Project from Example ‘RSDK_S32DS_template’" Create my Project successfully. Link: https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Create-New-Project-from-Example-...
but build all the project,Many errors occurred. How to solve it?
The RSDK version is
タグ(1)
5 返答(返信)
4,358件の閲覧回数
jone_yang
i update the code for the projects by suggest,then build again.
the another errors occured!
4,389件の閲覧回数
lukaszadrapa
it looks like the files are not generated. You need to update the code for the projects:
Lukas
4,356件の閲覧回数
jone_yang
add on the package :"BBE32 DSP Add-on package 1.2.0 for S32 Design Studio 3.4 Update 1",build again,then license error occured.
4,335件の閲覧回数
jiri_kral
did you download and install LAX compiler?
Jiri
タグ(1)
4,333件の閲覧回数
jone_yang
Hi, the LAX compiler installed
