Fresh installed S32DS 3.5 does not start - not supported 16-bit application
6,751 次查看
DenisT1980
I have installed the Version 3.5 from file S32DS.3.5_b220726_win32.x86_64.exe
Start the application via  s32ds.bat does not working. The fault message with title " not supported 16-bit application" is shown.
The version 3.4 is working correctly.
What could be the cause?
标记 (1)
6,543 次查看
Mehul_Patel_NXP
Hi, @DenisT1980
It looks like that an installation process done without admin/privileged rights
Please make sure you have administrator privileges and run S32DS installation with "run as admin" and reinstall.
Please follow the guide:
https://www.nxp.com/webapp/Download?colCode=S32DSIG
Please let us know if any further issue.
Thank you.
Kind regards,
-Mehul Patel
7 回复数
6,740 次查看
Mehul_Patel_NXP
Hi, @DenisT1980 ,
Please make sure that you follow the steps correctly as mentioned in this guide.
: https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
Also, please check if your computer OS or 64bit or x86 platform?
Please let us know the configuration of your PC. i.e Windows version, and 64bit or x86.
Thank you. Best regards.
-Mehul Patel
6,735 次查看
DenisT1980
There is no file under this link.
My Windows version is Windows 10 Pro 64-bit
6,723 次查看
Mehul_Patel_NXP
Hi, @DenisT1980 ,
Sorry may be glitch while copying the link:
Please check the link again with  login into your your NXP account. :
And, also rather trying with the .exe file for installation, please can you choose installer method:
Please let us know the update on the issue.
- Mehul Patel
6,706 次查看
DenisT1980
The .exe file I mentioned is Windows installer. I do not found any other.
6,686 次查看
Mehul_Patel_NXP
Hi, @DenisT1980 ,
Please can you share S32DS installation log:
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\Logs (or wherever your installation directory is located)
-Mehul Patel
6,678 次查看
DenisT1980
Thank you for answer. Here is the log.
6,544 次查看
Mehul_Patel_NXP
Hi, @DenisT1980
Thank you.
Kind regards,
-Mehul Patel
