EmbSys can't show register's value
2,308件の閲覧回数
jianmin_zhou
I try to check the register's value, but in EmbSys windows there is no any value shows? double click the register also no display.
check it in memory window , all show "?"
what is the problem?
2,169件の閲覧回数
jiri_kral
you are trying read write-only registers - that's why values for these particular registers aren't shown. Other registers works okay as you can see:
Jiri
