Debug always loads twice
1,520件の閲覧回数
tech3
Hello
When I do a debug build, the download ALWAYS FAILS the first time, then it has to redo the download which ALWAYS works the second time. (please see attached)
What am I doing wrong ?
S32DS on DEVKIT-MPC5748G  using example flexcan_mpc5748g
1,440件の閲覧回数
jiri_kral
from your attached console output is not visible that you need to flash program twice - it is standard debug session output. Can you describe steps how you are starting debug session?
Jiri
