Data Flash Memory: Value after Flashing again
1,420件の閲覧回数
avinashstarkenn
I am using S32k344 controller.
I have used 'C40_Ip_Example_S32K344' example for writing data in Flash memory.
I have changed address to write data in 'Data Flash memory' block.
Once the code is run the data is successfully written in this section.
But even after re-debugging/re-flashing still the data is retained in this section.
I was expecting whole flash memory to be erased and programmed again after re-debugging/re-flashing.
Is this the expected behavior?
#dataflash #flash
#flashmemory
#s32ds
1,392件の閲覧回数
lukaszadrapa
Hi @avinashstarkenn
this is known issue, it was already reported to Pemicro. It was discussed here:
https://community.nxp.com/t5/S32K/how-to-erase-the-whole-d-flash-every-time-with-PE-micro/td-p/16108...
Lukas
