Codewarrior project to S32 Design studio
4,819件の閲覧回数
maximillion
I want to open Code Warrior project in S32 Design Studio. It is possible? If it yes how can I do
thanks
7 返答(返信)
4,804件の閲覧回数
maximillion
Thanks for answering
Also, here is my second situation.
I have to open Code Warrior project in Kinetis Design Studio 3 IDE. Could you share with me AN about this topic?
4,784件の閲覧回数
Robin_Shen
4,773件の閲覧回数
maximillion
Firstly thanks for quick answer.
 I try to import Code Warrior Project which is complied GCC complier but I have an error.
GCC complier properly for kinetis design isn't it? I thought yes this error still exist.
How can I fix that? Could you give me tricks about this topic.
タグ(1)
4,742件の閲覧回数
Robin_Shen
Did you click Convert CodeWarrior project file...?
4,731件の閲覧回数
maximillion
Yes I clicked after that I included LIN_Stack libraries.
But I have error and warrnings. Code warrior used to FLASH for debug. Maybe this is problem?
I use to your recommended document actually step by step but cant still convert. Where is the problem?
タグ(2)
4,676件の閲覧回数
Robin_Shen
Sorry I am not familiar with this part, I suggest submitting this question to CodeWarrior for MCU.
4,812件の閲覧回数
Robin_Shen
I recommend you to read: AN5282 CodeWarrior to S32 Design Studio (S32DS) Migration Guide
Hope it helps.
Robin
