Calculated CRC-16 does not match block.
2,373 次查看
yangke
When we trying to download our project by PE, issue occurred as followed.
Is there any possible reason for this issue?
Connection from "127.0.0.1" via 127.0.0.1. Connection from port "54190" to 7224
Telnet server running on 127.0.0.1:51794
Copyright 2018 P&E Microcomputer Systems,Inc.
Command Line :C:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_2.0.4.202103012147\win32\pegdbserver_power_console -device=MPC5748G -startserver -singlesession -serverport=7224 -gdbmiport=6224 -interface=USBMULTILINK -speed=5000 -Ø
P&E Interface detected - Flash Version 6.15
Flash Data in range 0x00FA0000-0x00FA001B.
Flash Data in range 0x00FA0080-0x00FA1841.
Flash Data in range 0x00FA1844-0x00FA2393.
Flash Data in range 0x01000000-0x0100011F.
Flash Data in range 0x01001000-0x010010B3.
Flash Data in range 0x01002000-0x0100323B.
Flash Data in range 0x01007000-0x0100701D.
Flash Data in range 0x01007020-0x01051E5D.
Flash Data in range 0x01051E60-0x010593A3.
Flash Data in range 0x010593C0-0x010661BB.
Flash Data in range 0x010661C0-0x010661E1.
Flash Data in range 0x01066200-0x01066203.
Flash Data in range 0x01066220-0x01066281.
Flash Data in range 0x010662A0-0x0106BE13.
Flash Data in range 0x0106BE20-0x0106BFC3.
Flash Data in range 0x0106BFE0-0x0106D11F.
Flash Data in range 0x0106D140-0x0106D15F.
Flash Data in range 0x010C0000-0x010C011F.
Flash Data in range 0x010C1000-0x010C10B3.
Flash Data in range 0x010C2000-0x010C323B.
Flash Data in range 0x010C7000-0x010C701D.
Flash Data in range 0x010C7020-0x01111E5D.
Flash Data in range 0x01111E60-0x011193A3.
Flash Data in range 0x011193C0-0x011261BB.
Flash Data in range 0x011261C0-0x011261E1.
Flash Data in range 0x01126200-0x01126203.
Flash Data in range 0x01126220-0x01126281.
Flash Data in range 0x011262A0-0x0112BE13.
Flash Data in range 0x0112BE20-0x0112BFC3.
Flash Data in range 0x0112BFE0-0x0112D11F.
Flash Data in range 0x0112D140-0x0112D15F.
Flash Data in range 0x01180000-0x0118001F.
Flash Data in range 0x01180100-0x01180123.
Flash Data in range 0x01180300-0x01180303.
Flash Data in range 0x01180400-0x0118049F.
Flash Data in range 0x011804C0-0x0118057F.
Flash Data in range 0x01181000-0x011810B3.
Flash Data in range 0x01182000-0x01183B9F.
Flash Data in range 0x01187000-0x01386939.
Flash Data in range 0x01386940-0x0143150B.
Flash Data in range 0x01431520-0x0143F15D.
Flash Data in range 0x0143F160-0x0143F181.
Flash Data in range 0x0143F1A0-0x0143F1BD.
Flash Data in range 0x0143F1C0-0x0143F1DD.
Flash Data in range 0x0143F1E0-0x0143F1E3.
Flash Data in range 0x0143F200-0x0143F237.
Flash Data in range 0x0143F240-0x014705A1.
Flash Data in range 0x014705A4-0x014708F7.
Flash Data in range 0x01471000-0x01471189.
Flash Data in range 0x01472000-0x01472C0F.
Flash Data in range 0x01472C20-0x0147302F.
Flash Data in range 0x01473040-0x01476793.
Flash Data in range 0x01477000-0x0147847B.
Flash Data in range 0x01478480-0x01478E87.
Flash Data in range 0x01478EA0-0x01478EA7.
Flash Data in range 0x01478EC0-0x01478EDF.
Flash Data in range 0x01500000-0x0156849F.
CMD>RE
Initializing.
Device IDCODE is $00000082
Device ID revision is $00000000
Initializing Ram Block 0x40000000-0x40007FFF.
MPC574xC Device detected.
Target has been RESET and is active.
CMD>CM C:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_2.0.4.202103012147\win32\gdi\P&E\nxp_mpc5748g_1x32x1520k_cflash.pcp
Initializing.
DOUBLE BUFFERING enabled.
Initialized.
;version 1.05, 06/26/2017, Copyright P&E Microcomputer Systems, www.pemicro.com [5748G_6080k]
;device NXP, MPC5748G, 1x32x1520k, desc=CFlash
;begin_cs device=$00F90000, length=$005F0000, ram=$40000000
Loading programming algorithm ...
Done.
Programming sequency is : erase, blank check, program, and verify {default}
CMD>VC
Verifying object file CRC-16 to device ranges ...
block 00FA0000-00FA001B ...
Ok.
block 00FA0080-00FA1841 ...
Ok.
block 00FA1844-00FA2393 ...
Ok.
block 01000000-0100011F ...
Calculated CRC-16 does not match block. (File = $32D7, Device = $5D88)
Current content of flash does not match application to be programmed
CMD>EM
Erasing.
Error : Error in ONCE status register during instruction execution.
Module has been erased.
CMD>PM
Programming.
Processing Object File Data ...
2,335 次查看
jiri_kral
