CLK Check bug Q&A
已解决
CLK Check bug Q&A
跳至解决方案
1,777 次查看
SW_S
hello, NXP Team.
i'm using the FlexCAN0_CLK check box and flexCAN1_CLK flexCAN2_CLK disable.
If you turn off and on S32k design studio, flexCAN0_CLK, flexCAN1_CLK, and flexCAN2_CLK are all checked.
Even if I uncheck it and save it, it stays checked again when I turn it off and on. Is there a way to do this?
1 解答
1,768 次查看
Robin_Shen
Sorry for the inconvenience we bring you! And thank you for the report. This is a known issue.
Please use the latest S32DS v3.4+S32K1 SDK RTM 4.0.3. (The newer SDK fixes issues in the older SDK. The List of fixed issues can be found in SDK's Release Note.)
Robin
在原帖中查看解决方案
2 回复数
1,769 次查看
Robin_Shen
Robin
1,764 次查看
SW_S
thank you,
have a nice day!
