I have an actual project running on S32 Design Studio for S32 Platform V3.4 with RTD 2.0.1.
I want to update it to use FreeRTOS for the moment and migrate it to SafeRTOS later.
I don't find any packages for FreeRTOS on S32K3xx, there is any package library to add with this software and easy configuration tools or i have to add manually the FreeRTOS ?
Is it better to work on S32 DS for ARM to work with FreeRTOS on this S32K3-T-BOX board ?
Thank you.
已解决! 转到解答。
Hi @Rab06
FreeRTOS packages can be found in S32K3 Reference Software package:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
S32DS for ARM does not support S32K3 devices, use S32DS for S32 Platform instead.
Lukas
Hi @Rab06
Lukas
