Activation Error S32DS 3.4 & 3.5
1,699件の閲覧回数
hhl
I am new to S32 series. I'm using S32K144 on a new design. I installed the latest S32DS v3.5 last week, and activated without issue. This week, i start S32DS and I get license error. Trying to activate again with the same activation code has given me this error message: "Error sending an activation request to remote activation server and processing the resulting response. (FNP error 50040, 41147,10250)".
I tried offline activation, but that also failed with error message: "Error processing offline response, ResponseType ACTIVATION (FNP error 50019, 41200,10250)".
How do I activate my the license? Does this license require periodic renewal?
I also tried installing S32DS 3.4 and getting the same errors for online and offline activation.
On another note, most "getting started" tutorials seem to be using that S32DS v3.4. And the latest S32SDK 4.0.3 is apparently available on S32DS 3.4, but only SDK 4.0.1 available on DS 3.5. I'd like to confirm the right versions to use for new designs of s32k144.
1,331件の閲覧回数
Maka_Zhang
Hi, Have you solved it now
