write to text file
write to text file
2,941 次查看
writetotextfile
I am using 68HC(S)12 . I want to write the results of analog to digital conversion into a text file. Anyone has any helpful hints.
thanks
s
标签 (1)
3 回复数
2,072 次查看
pittbull
You can send the data over SCI to a PC...
2,072 次查看
Nicklop
But how to do it in the program?
Any example?
2,072 次查看
allawtterb
Is this just for testing purposes or will it be part of the final product?  If it is for testing purposes, the FreeMASTER program provided by freescale be setup to do this very simply.
Otherwise, you can use the SCI as mentioned above to send the data over RS-232 to a computer, you will have to write an application on the computer to log the data or find a free RS232 monitor program that allows logging of data.
