write to text file
write to text file
writetotextfile
I am using 68HC(S)12 . I want to write the results of analog to digital conversion into a text file. Anyone has any helpful hints.
thanks
s
pittbull
You can send the data over SCI to a PC...
Nicklop
But how to do it in the program?
Any example?
allawtterb
Is this just for testing purposes or will it be part of the final product?  If it is for testing purposes, the FreeMASTER program provided by freescale be setup to do this very simply.
Otherwise, you can use the SCI as mentioned above to send the data over RS-232 to a computer, you will have to write an application on the computer to log the data or find a free RS232 monitor program that allows logging of data.
