stack size during linking time
grzegorzK
Hi all
I wonder if is possible to get a stack size in "c" module during linking time? I am using FreeScale compiler.
e.g.:
extern unsigned __stack_size;
unsigned stack_size()
 return  __stack_size;
I was looking in linker map file, but seems there is not any object connected with stack size, only with top of stack.
Any clue?
/Regards
kef
Specialist I
Try searching online help for __SEG_SIZE_SSTACK
extern int __SEG_SIZE_SSTACK[];
int a;
   a = (int)__SEG_SIZE_SSTACK;
grzegorzK
Exactly what I needed...
Cheers!
