s12x - Eeprom
s12x - Eeprom
2,785件の閲覧回数
vandenplas
How do I write/read to the eeprom using the s12x
I'm using a 4Mhz external clock with no PLL.
What do I set ECLKDIV to
Is there any sample code in C I can look at?
1,100件の閲覧回数
Technoman64
You should be able to download the latest version of Codewarrior for the HCS(X)12 mcu and use Processor Expert to create code to access the EEPROM.
Even the Special(free) version has this feature.
