interrupt test package avaible
1,788 次查看
rajesh057
Hi ,
I am using S12zvc microcontroller .specially I would like to check my interrupts at starting of the code ,run time and end of the code .is their nxp packge is available to check core of the interrupt .
thanks
Rajesh Kota
1,646 次查看
dianabatrlova
Hi Rajesh,
I'm not sure if I understand well your question.
How do you imagine the controlling content of interrupts or what do you want to check?
Do you need help with a specific interrupt?
Thank you.
Diana
1,646 次查看
rajesh057
Hi Diana,
Sorry for delay .
yes i would like check cpu interrupts.
Thanks ,
Rajesh Kota
1,646 次查看
dianabatrlova
Hi Rajesh,
I would like to ask you, is this question related to your newer case SWI AND SYS TEST?
Thank you.
Diana
