hc12 + seimens gsm modem
mas123
My hc12 could communicate with my westermo gsm modem via serial ports. However, when i change the type of modem to siemens mc35i i can no longer communicate with my modem. What can be the problem? I could communicate with siemens modem using hyperterminal but not using hc12?\
I appreciate your help.
nikosxan
Hi. I'm not aware of the specific modems, can you explain ?
Are the setting for Com ports the same ? what setting you set for HYPERTERM for the 2 of them ?
Nick
