erase and write data into flash dsp56f8013
Haram80
I need to write assembly code to save parameters into the flash of the 56f8013. There is some sample code or toutorial that explain clearly  how to erase and write dynamic data? someone can help  me?
J2MEJediMaster
Specialist I
In the keyword search box at the upper right of this web page, enter "FAQ-11548". This will bring you to a FAQ that covers some information on Flash programming for the DSP56fxxx family. It has links to other FAQs that address specific DSPs. Give it a look. Also, you can enter "Flashing Programming" into the same facilty and you'll get a display of quite a few Flash programing documents. You'll have to wade through those to find the ones specific to your DSP, though.
---Tom
