ZVMC128 GDU not configuration on ProcessorExpert
byeongjinkim
Error message
Description Resource Path Location Type
ERROR: Unexpected status of script: Drivers\HCS12Z\InitPin.prg, please contact Freescale support. TestGDU_ZVMC128 GDU Processor Expert Problem
ZVMC128 not configuration
ZVML128 is OK
how can i correction?
RadekS
Hi Byeongjin,
It is not clear from your screenshots whether your configuration for GDU at S12ZVMC and S12ZVML are the same.
Could you please provide example project with PE configuration which will highlight described issue for future analysis?
I hope it helps you.
Radek
