try the below ATD1 init function. There is PLL init function as well at the end.
void init_ATD1(void)
ATD1CTL1 = 0B01010000; // ATD Control register 1
// Bit 7 = External trigger source select - 0 is an A to D channel
// Bit 6,5 = A/D resolution select - '10' is 12 bit
// Bit 4 = Discharge before sampling bit - enabled
// Bit 3,2,1,0 = External trigger channel select - 0 (with bit 7) is AN0
ATD1CTL2 = 0B00000000; // ATD Control register 2
// ICLKSTP set, allows A to D clock to run in stop. ATD Compare interrupt enabled */
// Bit 7 = Not Implemented
// Bit 6 = ATD Fast Flag Clear all - disabled
// Bit 5 = Internal clock in stop mode - disabled
// Bit 4 = External trigger level / edge control - not relevant
// Bit 3 = External trigger polarity - not relevant
// Bit 2 = External trigger mode enable - disabled
// Bit 1 = ATD Complete interrupt enable - disabled
// Bit 0 = ATD Compare interrupt enable - disabled
ATD1CTL3 = 0B10000010; // ATD Control register 3
// Bit 7 = DJM (Data Justification) - 0/1 is left/right justified
// Bit 6,5,4,3 = Conversion sequence length - '0000' (16 conversions / sequence)
// Bit 2 = result register FIFO mode - 0 for non-fifo
// Bit 1,0 = Background debug freeze enable - '10' finish current conversion then freeze
#if PLL==1
ATD1CTL4 = 0x02; // ATD Control register 4
// Bit 7,6,5 = Sample time select - '000' is 4 ATD clock cycles
// Bit 4,3,2,1,0 = ATD Clock prescaler - '00010' clk freq = fbus/(2*(2+1)) = 50MHz/(2*(2+1) = 8.33 MHz #else
ATD1CTL4 = 0x00; // ATD Control register 4
// Bit 4,3,2,1,0 = ATD Clock prescaler - '00000' clk freq = fbus/(2*(0+1)) = 8MHz/(2*(0+1)) = 4 MHz #endif
ATD1DIEN = 0x0000; // ATD Input enable register
// Bit 15 - 0 = ATD digital input enable on channel n - (not enabled on any channel)
ATD1CMPE = 0x0000; // ATD Compare enable register
// Bit 15 - 0 = Compare enable for conversion number n
ATD1CMPHT = 0x0000; // ATD compare higher than register
// Bit 15 - 0 = compare operation higher than enable for conversion number n - (compare if higher than for n = 0)
ATD1CTL5 = 0B00110000;// ATD Control register 5 (Write clears conversion complete flag in ATD1STAT2)
// Special channel conversion disabled, continuous conversion enabled, multi mode disabled. Lower nibble sets channel 0 */
// Bit 7 = Not implemented
// Bit 6 = Special channel conversion bit - disabled?
// Bit 5 = SCAN (Continuous conversion sequence mode) - enabled
// Bit 4 = Multi channel sample mode - enabled
// Bit 3,2,1,0 = Analog input channel select code - '0000' is AN0
void init_PLL(UBYTE _synr, UBYTE _refdv,UBYTE _postdiv) {
PLLCTL = 0B00000001; // clock monitor - off
// PLL - off
// VCO modulation 00-Off,01-1%,10-2%, 11-4%
// fast wake up - off
// RTI - off
// COP - off
// SCM - on
CLKSEL = 0B00100011; // clock = OSCCLK
// pseudo stop - off
// external clock used (canned oscillator)
// 0
// PLL in wait mode - on
// 0
// RTI in wait - off
// COP in wait - off
SYNR = _synr ;
REFDV = _refdv;
POSTDIV = _postdiv;
PLLCTL_PLLON = 1; // PLL - on
PLLCTL_CME = 1; // clock monitor - on
while(!CRGFLG_LOCK); // Wait till the PLL VCO is within tolerance
CLKSEL_PLLSEL = 1; // Select clock source from PLLCLK
